These have been carefully recreated/copied from a Peplink MediaFast 500 HwV2 FwV7.0.1
Source is taken from the URL of http://cert.peplink.com/#instruction_nt6 (NOTE: This URL and the “Certificate Download” link below can only be accessed from within the MediaFast LAN network, this is done partly due to the unique certificate file within each MFA system.)
Peplink MediaFast
Certificate Installation Instructions
Open certificate file
Click Open in the Open File - Security Warning dialog
Click Install… in the Certificate dialog
Click Next > in the Certificate Import Wizard
Select Place all certificates in the following store, and then click Browse…
Select Trusted Root Certification Authorities, and then click OK
Click Next >
Click Finish
Click Yes in the Security Warning dialog
Click OK
Close all browser windows and then open this page again to verify certificate installation, or contact your IT administrator for assistance.
