These have been carefully recreated/copied from a Peplink MediaFast 500 HwV2 FwV7.0.1
Source is taken from the URL of http://cert.peplink.com/#instruction_ios (NOTE: This URL and the “Certificate Download” link below can only be accessed from within the MediaFast LAN network, this is done partly due to the unique certificate file within each MFA system.)
You need to use the devices built in Safari web browser to do this, this process does not work from Google Crome (based on devices with iOS 9.x).
Peplink MediaFast
Certificate Installation Instructions
Tap Install in the Install Profile screen
Tap Install in the Warning screen
Enter passcode if necessary
Tap Done in the Profile Installed screen
Reload this page to verify certificate installation
