These have been carefully recreated/copied from a Peplink MediaFast 500 HwV2 FwV7.0.1
Source is taken from the URL of http://cert.peplink.com/#instruction_android (NOTE: This URL and the “Certificate Download” link below can only be accessed from within the MediaFast LAN network, this is done partly due to the unique certificate file within each MFA system.)
Peplink MediaFast
Certificate Installation Instructions
Enter Root CA under Certificate name, select VPN and apps under Credential use, and then tap OK
Reload this page to verify certificate installation
