Peplink Max Transit Pro with Canadian SIM
I have been using my Peplink router with an ATT sim without any issues; excellent service. I tried replacing the ATT sim with a Canadian provider called Public Mobile (owned by Telus). The Public Mobile SIM has a data plan just like the ATT sim; however when it is plugged in to the router, an IP address cannot be configured. Are these router locked to use only American cellular providers? I am using this router in my Airstream RV, it came with the RV.
If you’re not getting an IP address then authentication is likely failing.
Have you tried setting the APN manually? (I think it should be isp.mb.com)
Thank you Martin, the APN you provided worked. Much appreciated.
