Peplink MAX Transit Duo Pro with Hologram SIM stuck with Cellular "Initializing"
Hologram SIMs
8.5.1 build 5714
Custom configured with “hologram” APN
Both Cellular channels are showing “Initializing” and no Cellular LED at all.
HI Brian,
Welcome to the forum!
Have you tried using the sim cards in a phone?
Some times there are sim cards that only be used in a phone.
Also is roaming needed to be enabled?
Hope this helps :slight_smile:
Regards,
Joey
Thanks! I don’t see a roaming setting, where would I find that?
No problem :slight_smile:
In you webadmin dashboard go to your cellular WAN options:
Then you will scroll down to Cellular settings and above the APN settings you can find Data Roaming. check the box:
Hope this helps.
OK I don’t have that option - different version of firmware perhaps. I’m at 8.5.1 build 5714
I rounded up another Router same model. This is working with a Hologram SIM and the interesting thing is that the configuration includes a Peplink eSIM option which is used by the working router. See the attached image
The broken Router does not have the Peplink eSIM option which may be significant? How do I get the Peplink eSIM option enabled?
There’s 2 hardware versions of that model, what version is the working and non-working unit?
Both have the same model number. A227 is the bad Peplink.
I should note I did downgrade the firmware version so they match.
Sent you a DM, let’s get this on a ticket and troubleshoot further
This issue has been resolved by Peplink support with remote access enabled on the Router. Details are not known.
@Zakk_Stewart what was the root cause?
Peplink has assisted directly in this case, I do not have additional insight.
