I am having lots of issues with the Peplink Max BR1 - and wondering if there are some ideas on how to fix these. I would rather fix it then return the unit.
So - here is the situation- I have a Verizon SIM, and a static IP from verizon.
Here is what happens - either it sits there and alternates between “connecting” and “obtaining IP” over and over but never connects.
The other state is - it says “SIM PIN required or Incorrect”
I found out that I probably have to put mw01.vzwstatic in the APN - but now I get the SIM PIN thing on two different devices
I spent over two hours messing with this yesterday and I need to get a solution. We put the same sim into a cradlepoint and it just connects with no issues at all, also a d-link no issues.
Also is there any support number for this product or help getting it setup?
Would you please upgrade the device using the latest firmware and verify again ? You can download the latest firmware using the following URL :
If the issue still persisted using the latest firmware, you can open a support ticket to allow support team to check on the issue : https://ticket.peplink.com/ticket/new/public
FWIW: We have deployed Verizon SIM cards with static IP addresses across devices (HD2s, BR1s) for a number of years. In the early days we had to enter the APN for the static IP, but that seems no longer necessary. I have not encountered a request for a PIN. (The SIM cards were all delivered from Verizon without a PIN set, and we never set the PINs ourselves).
I had another one just start from working to “connecting” and nothing would fix it. I tried the APN, the pin code - mw01.vzwstatic and upgrading firmware and everything else. It did not connect. I ended up replacing it for another unit- but this is the 2nd one so far that has done this. Any ideas? do these not handle static IPs very well with verizon- or any idea what could be causing this?
