While we configure MAX HD2 in KSA, we used two network SIM cards (STC & Mobily).
STC SIM was automatically established the network/internet but Mobily was NOT!
Problem occur due to APN not defined automatically in MAX HD2 for mobily SIM card.
After we set Mobily SIM APN “web2” (Image Attached) it start to work fine.
Please check with Mobily whether the prepaid APN should be used in postpaid SIM card since prepaid and postpaid do have different APN. Fyi, the APN is controlled by the ISP.
@akbar12 I think you were misunderstood.
I am using “Mobily” network provider and I am using their APN. Your link / website not having Mobily network APN setting.
I am checking with Mobily provider to get official confirmation. Once I receive I will add it here.
