Hi Peplink Team,
Now a days we have 5G (LTE) network in Saudi Arabia (KSA).
I know Peplink devices are support with 3G and 4G. I need to know 5G support with your Peplink MAX HD2 and Peplink Balance 305?
Expect your prompt reply.
BR.
Hi Peplink Team,
BR.
Please have a look at this page and the whitepaper that follows: https://www.peplink.com/technology/5g-wireless-sd-wan/
As always, do let us know if this helped or if you have any follow-up questions.
Thanks for the link 5G-Wireless SD-WAN.
But in our case, we have 6 MAX HD2 devices and 2 Balance 305 devices.
It is not easy to change all to different model devices only for 5G and cost wise it is difficult as well.
I am looking for a solution with 5G capable option in MAX HD2 and Balance 305.
You mean, above mentioned devices (HD2 and 305) technically or mechanically will not support with 5G?
Thats right. You need new platforms to support 5G.
Peplink’s new 5G devices are modular. So future cellular technology updates, doesn’t mean you need to upgrade the whole device, but switch the modems out.
Due to the higher throughput requirements with 5G all Peplink 5G devices are new developments, not just upgraded models.
By the way, due to CITC requirements in Saudi Arabia only the CAT18 or 5G version are approved for usage in KSA. More information: Saudi Arabia | CITC | Peplink VAD | ADVANTESCO
You can contact our UAE or Saudi office for more information
