Peplink MAX BR1 Pro 5G with T-Mobile, keep losing internet
Just received this with a Parsec Husky Pro 7-in-1 Antenna. I took the 5G SIM out of the T-Mobile provided T-10 hotspot and put it in the Peplink. Everything started right up and I had 5G internet (sometimes LTE) within minutes and seemed fine. HOWEVER, it keeps losing internet, even though it says it has 3-4 bars typically. The hotspot always had 3-4 bars and maintained internet in the same location.
There are a LOT of options that can be set, so wondering if this is my issue with some setup needs or if I have a hardware issue. I have set it to priority, disabled idle timeout, etc. - any thoughts?
I think the first thing I would do is to check with TMO and ensure they are OK with you using that SIM in another device. Some plans require you use the same box (by IMEI.) We’ve seen cases where a SIM, when moved, either does not work at all or “partially works.”
My guess is your settings on the Pro 5G would not cause the issue you are seeing – that’s not where I’d start looking.
