I need some help, Ive been working with the Peplink max BR1 mini and the Starlink flat high performance to attach to the roof for off roading I’m looking at just using the starlink, Not the sim cards. Ive been going through, and it took hours just to get some WiFi working and Im not even sure what really changed other than a reboot. From everything I’ve looked at it seems as if I’m missing Starlink specific settings, nothing but the empty sim card slot shows up when trying on dashboard and network and I’ve also checked advanced settings and I’ve had no luck. Any help would be greatly appreciated!
You need to update the firmware to 8.4.0 or greater to enable the advanced Starlink support.
Either your primecare is expired, you don’t have a feature pack installed, or you aren’t running 8.4 or greater.
Also Starlink integrations is currently only available on wired wan, but this might change on wifi-as-wan.
Hey, Thank you for the help! Ive updated to the latest firmware, And Ive disabled the LAN settings letting WAN being used as LAN, Which allowed the WAN to show up in the Wan connection Status on the dashboard, However WAN still isn’t connecting, nor showing the Starlink symbol. Ive enabled WAN in Starlink settings and I’m not too sure what to do from here.
Hi.
BR1-mini need to validate his license… After your update… Let the device connected at Internet. Just for a few minutes.( even for WAN license )
It worked, I also seem to have a semi faulty cable which made things more complicated. Thank you for the help1
