Does the peplink max br1 5G come with an IMEI number that works with a Verizon data only plan. I have read online that you have to have a business account in order to use The Verizon Sim/data package with the mobile router.
Have attached a link to devices approved on the Verizon network.
https://opendevelopment.verizonwireless.com/device-showcase
Search for Peplink and you will find the BR1 5G is certified. I would go to a Verizon corp. store to get the SIM. They typically have persons a little more knowledgeable and should be able to get you up and running
If your cellular phone carrier is with Verizon, the process is a lot easier as they add another # to your account. have used Verizon as my non-business cellular phone carrier for years. Don’t know what sort of hassle it would be if I just wanted a data only plan. It’s a ‘Mobile Hotspot’ in the Verizon vernacular.
Hope this helps.
