I have a network composed of a Balance Two, a Peplink 24 port switch, and 3 AP One AXs. For some time now I have been trying to get Lutron automation systems to work on the network. The Lutron controllers, which depend on multicast, are wired into the Balance Two or the 24 port switch, while my iPhone with the Lutron app connects via wifi. In general I would describe the connections from the phone to the Lutron controller as “fragile”. I just updated to the latest firmware on all of the network devices since I know a lot of changes have been made to better support multicast in the last couple years.
I was eventually able to get the Caseta to work by enabling IGMP Snooping on the Wifi network and connecting it via ethernet to the Balance Two. Painful, but once it was setup it was pretty reliable.
No such luck with the Radio RA3. I have gotten to the point where the iOS app sees the Lutron controller on the network, but as soon as I press the setup button on the controller the connection breaks (exact same behavior I observed with the Caseta). I have tried IGMP Snooping on/off but it doesn’t seem to matter for the Radio RA3. I have noticed that the only way my laptop (which runs the software to program the Lutron controller) can connect is if I change the ethernet ports on the switch from Trunk->Any to Access->[VLAN] for the controller and laptop. And of course the Wifi network is on that same VLAN.
I have run out of ideas; curious if anyone else has any. I have a call in to Lutron support. Thanks
