How does lowest latency algorithm works? When it select WAN link, to which destination IP it send periodic packet to determine round-trip-time ?
Is it based on Destination IP specified in the outbound policy ?
I have requirement to route certain traffic , for example traffic to www.apple.com out of WAN link which have lowest latency to www.apple.com . Possible to do?
This algorithm will send periodic packets to the device 2-3 hops ahead of the WAN connection to determine round trip time, and the one with the lowest value would be used.
For your case, I would suggest you do a traceroute from the Balance’s WAN interfaces to the desired address and then just make an outbound policy rule using priority or enforced algorithm.
