PepLink Lan Network - Can Not Delete "Used By"
For whatever reason, I can not delete this vLan network, it says just “Used by” and I have looked everywhere for where it could be. The network is not used anywhere.
And I have rebooted.
See if you have it set as a named VLAN on a specific physical port.
Also check to see if a speedfusion layer 2 profile is using it.
