Hello, someone has made IPsec VPN Peplink to router Huawei AR 1200
Peplink officially supports IPSec VPN with Cisco, Juniper or Peplink devices only.
Hello, try IPsec tunneling with Juniper SSG 550 using BR1 but it was not possible to establish the tunnel, I followed the instructions of Knowledge did not work the connection.
Juniper SSG550 menus are very different from those in the documents Peplink, have you done tests with this model SSG550 Juniper?
I can help if someone already did that test
Please share the settings of BR1 and SSG550. Please open ticket for us to check further if this is sensitive.
Thank you.
