Good morning.
I need a recommendation for a peplink hardware for a corporate event. Up to 200 users. These users basically need to have access to the internet. Nothing too complex. I don’t need SFC, only cold FailOver. Any suggestions?
Good morning.
Hello @danielmagalhaes1985 ,
What is the throughput you’re expecting?
Are you looking it to be only cellular?
Do you have ISP fibre connection available?
Have a look at the 310 range… is that in the area of what you want?
Hello thank you for the feedback.
Link ISP 500MB/500MB + Starlink FailOver.
Internet only. WhatsApp, social networks.
From the basic information that you have given, you will be looking at one of the higher rated units, as you will need a unit capable of 2.5Gbps or more on the back plane and 2 WAN ports. Something like the Balance 310X.
Depending on your location, I recommend you contact a Peplink reseller local to you, as they will be able to give you the support to ensure it is also correctly configured.
We are a peplink reseller and can assist, send us an e-mail at [email protected]
