I’d try with the 305 WAN set to DHCP first and see what happens. If that doesn’t work change it to static IP to match the settings on the HG8245 instead.
Hi Martin,
i would like to thank you first for ur availibilty
if i choice static IP on PEPLINK WAN the only change is that i affecte an IP addresse whithin the same network with LAN of HG8245 and i need to set up the gateway (IP LAN addresse of HG8245)
To start yes. Assuming the HG8245 is configured in the way you want.
Routers on the WAN of a Peplink can either provide a NATTED private IP address to the Balance or they can sometimes be configured as a bridge so that the public IP is presented to the WAN of the balance.
Being set as a bridge is normally better where possible.
So it depends on your use case for the Peplink, maybe you don’t need any (or many) inbound ports opened, in which case just add the ports you do want here individually.
However if you just want to manage port forwarding on the peplink then you could forward all ports on the Hg8245 wan to the IP address of the balance now, and manage port forwarding from the wan of the peplink to internal IPs later on the balance ui.
