I’ve noticed this a few times in the past and don’t remember if I figured out what was wrong. Basically, going to https://estore.peplink.com/ in either Firefox of Chrome on Linux Mint just loads a blank white page. I just tested on a separate machine running Macos with Chrome and the same thing. Is the store down?
FWIW: The page loads in Chrome (Version 101.0.4951.54 (Official Build) (arm64)) and Safari (Version 14.1.2 (16611.3.10.1.6)) on a MacBook Pro (13-inch, M1, 2020) running MacOS 11.6.2
Cheers,
Sigurd
I’ve had the same problem myself. I’m using Ublock on Chrome, and I found that it was the reason I was getting a blank page. Turning it off fixed it for me. See if any adblockers might be causing the problem.
Best,
Zac
It won’t load on Safari, Firefox Dev, or Brave for me on macOS (all latest versions). Brave is my “trash” Chrome browser with no ad blockers etc installed, though the browser itself does that so that could be my issue. Safari & Fox both have ad/privacy extensions installed.
Yup, looks like turning ublock off made it work for me.
I thought I had attempted on a plain vanilla browser earlier but perhaps not.
