I signed one of my peplink max br1 mini 5G modems up for the peplink esim data plan, is it possible to get this plan on a public static IP address rather than the provided IP?
On the peplink dataplans you can only “get a static” if you do a speedfusion tunnel to a vm that you host.
We have ATT,TMO,VZW plans with static ip if you need them.
Is it relatively easy to set up on our VM host
Sorry, what is a vm?
Google it…
The host VM is the physical machine that provides the guest VM with computing hardware resources , such as processing power, memory, disk, network input/output (I/O). A guest VM can exist on a single physical machine but is usually distributed across multiple hosts for load balancing.
VM = Virtual Machine
