Can someone comment content blocking, particularly the categories “update sites” and “file hosting”???
After you have enabled content blocking you can download the list via the status page:
Where can I view what sites are blocked?
Great I can see the file is a CSV! What is the CPU overhead when this database is loaded?
There is no set percentage here, it all depends on what else is running like FW rules, QoS, etc…
well it’s a 500,000 hosts list! I don’t believe that all this comes at no cost…
Before attempting to load this I wonder if someone has tested the overhead or delay that may occur on this…
I have discovered that my Balance One has allready the same list loaded! I have downloaded the database and compared with the suggested DB, files are identical! Comments?
