Hi Support,
The BR1 Max Pro 5G support WiFi Standard : range between 250 ~ 300 ft?
Regards and Thanks,
Bit.
Hi Support,
Regards and Thanks,
Bit.
Out in the open? No walls or obstruction? What band? What power level?
I have a BR1 Max Pro mounted with a 42G antenna (6’ coax) about 8 feet above the deck and 12-13 feet above the water. I can stay connected with my iPhone walking maybe 300 feet away down the dock. After that, it gets intermittent - and if anything metallic gets in the way, not that far.
Hartley
