Any body experiences with Satarlink new services ie : Layer 2 Private Network ?
I have customer need to make point to point connection with 5 Starlink at remote and a Backhaul at HQ with LACP .
Previously we do POC with L3 Starlink services and make SFVPN between to Balance. no issue.
Problem is the real configuration they use new services from starlink that use Layer 2 end to end services and manage by VLAN . Each Starlink unit have 2 VLAN so for 5 starlink terminal there will be 10 VLAN.
We use SDX with TWO WAN PORT and 3 Virtual WAN so it can work for 5 Starlink connection.
at remote site Peplink WAN port can manage only 1 connection/ VLAN , so only can accomodate 5 Starlink VLAN.
At he Backhaul our SDX also only have 2 WAN Port and no Virtual WAN.
How do we mapping 10 VLAN (5 Starlink unit ) to one or two WAN port at HQ ?
can we use LAN PORT at HQ SDX with multiple VLAN (10) to make point to multipoint (5 starlink with 10 VLAN ) and do bonding ?
This is interesting. I haven’t had a chance to play with the new L2 services yet. We’ve only done full L2 PNIs at the datacenter end which is perhaps easier from a topology perspective.
Why are their 2 vlans? Whats the purpose of two rather than one per terminal?
in remote Side, SDX with 3 Virtual WAN Connect to 5 Sarlink with datapool services. each connection have its own VLAN. in backhaul because we only have 2 WAN Port and its not support multiple VLAN we add another router that convert 5 VLAN from remote to TWO VLAN to SDX Backhaul. then we create L2 SF VPN between this two SDX.
End to End we use mi**otik router to simulate traffic generator for sending and receive paket.
With this configuration we achieve 400 Mbps TCP download and 550 UDP download.even when we try to generate 2 Gbps traffic in mi**otik.
Any experienced with this configuration ? why we can not get higher throughput wile SDX suppose to get 1 Gbps SF VPN, no encription ( datasheet).
First design was with L3 Starlink, so 5 remote can bonding directly to one or two backhaul for redundancy. but then its change the starlink services to L2 data pool. They got two VLAN from starlink for each of L2 services that can connect to DC and DRC i think, but sice our peplink WAN only support 1 VLAN. we can only use 1 VLAN per starlink.
Need advice to get more throughput, because they expect more than 700 Mbps for this configuration.
I came across this forum thread and found it really useful. We’re working through a similar design (bonding multiple Starlink terminals over their PNI) and would love to learn from what you’ve already figured out.
A few things I’m hoping you can share:
Two VLANs per terminal
In the thread you mentioned each Starlink L2 terminal hands off two VLANs, possibly tied to DC/DRC paths. Could you confirm the actual purpose of the second VLAN, is it for redundancy/failover to a secondary data center, a separate management path, or something else?
Final architecture
Could you share the final topology you landed on?
Throughput results and lessons learned
What was the performance you able to achieve compared to L3 services?
Any lessons learnt would be great help.
I’d really appreciate any details you’re able to share.
