We are happy to announce Firmware 5.4.7 RC, please try and you also can post the comment in Beta Feedback forum](Peplink | Pepwave - Forum)
Download links:
Peplink Balance 20/30
http://download.peplink.com/firmware…-build1648.bin
Peplink Balance 210/310 Hardware Revision 1
http://download.peplink.com/firmware…-build1920.bin
Peplink Balance 210/310 Hardware Revision 2/3
http://download.peplink.com/firmware…-build1493.bin
Peplink Balance 380 or above
http://download.peplink.com/firmware…-build2423.bin
Pepwave MAX 700/HD2
http://download.peplink.com/firmware…-build1941.bin
Changes to Firmware 5.4.7 since 5.4.6**
Added:
- HA failover will be performed if all WAN links of Master unit go down
- New SpeedFusion connection states on Dashboard
Improvement:
- SpeedFusion stability and performance
- Local DNS Proxy stability
- Stability of Outbound Policy by domain name
- Stability of HA configuration sync
**IMPORTANT NOTE **
- Please upgrade to firmware 5.3.12 before upgrading to firmware 5.4 (B20/30 only)
- SpeedFusion Site-to-Site VPN 5.4 is also backward compatible with firmware 5.2/5.3
- For the best performance, we recommend to use latest 5.4 firmware in all VPN peers
- Firmware 5.4 now utilizes TCP port 32015 and UDP port 4500. (Firmware 5.2/5.3 used TCP port 32015 and UDP port 32015)
