Hi, I’ve been attempting to set up my Peplink Balance One to connect to Starlink. I’ve installed the firmware that adds support for connecting to the Starlink admin, but I’m still unable to connect. Are there any instructions available anywhere on how to set up Starlink to connect to the Peplink Balance One?
The balance one just needs the lastest firmware - nothing special.
Then you plug the Starlink into its WAN port and off you go.
You should add a management IP to the WAN settings of the Balance One so that you can manage the dish from the LAN using either the web interface on a laptop (https://192.168.100.1) or the Starlink app on your phone.
Is Starlink itself working? What happens when you plug it into your laptop can you access the internet?
