sorry, but I don’t know why do I have to make any configuration on the swith, once I did that same configuration on the peplink 20, and it works fine.
I’m using the ap management by the peplink to set up the pepwave. So, if I use the pepwave vlan “untagged”, it works fine, but the dhcp gives range 192.168.0.x, this is the satured ip range. When I use the vlan 1 that is the range 192.168.1.x, the wireless network can’t give an ip address.
So, as this same configuration worked fine on peplink 20, without setting up the switch, I’m thinking that I’m missing something in peplink 380
thanks
