Hi Guys
I am having some issues with NAT on a Balance ONE and PFsense , maybe someone can point me in the right direction.
Network is setup as follows.
Peplink Balance One with 2 x Wan Connection with static ip’s (172.16.1.1 -Lan IP) ---- PFsense with 2 network cards ( Wan Side = 172.16.1.2 with Peplink IP as gw) –> Lan side (10.0.1.3/20) –> 2 switch with DHCP enabled on PFsense giving out 10.0.1.0/20 addresses.
Now on Peplink I made NAT rule to forward all traffic to 172.16.1.2 PFSense Wan IP port 444 to access pfsense from home - This rule works perfectly and i can manage the firewall from remote sites.
Now I am trying to add another rule on peplink to allow a connection to a pc on the lan with 10.0.1.81 on port 1433 using the same port forwarding rules on peplink but the traffic does not even reach the fw . (system logs would atleasst indicate a attempted connection but its not)
Where am i going wrong am i missing something.
Help with this will be appreciated , if you require more info please dont hesitate to contact me
