Hello
I have a Peplink Balance One, and multiple unmanaged switchs with more than 50 connections under it.
I made 2 VLANs (one for VOIP and another one for workstations).
VOIP 192.168.2.49/24 (VLAN 50)
Workstations 192.168.80.1/24 (VLAN 8)
The problem is, that I do not want to use DHCP and whenever I use a configuration for a workstation as 192.168.80.5/255.255.255.0 under default gw 192.168.80.1, It doesn’t connect.
I found out the problem is that I am not taggin the connection as VLAN 8, and I cannot make a trunk, as I share the swicth with multiple configuration (VOIP/Ws).
So I would like to know if it is possible to tag a VLAN based on NAT configuration (IP Address 192.168.80.1/24 -> tag as 8) or is there any other way, as I cannot make any trunk based on the current situtation.
The only solution I have is to manually tag the WS but that’s not a good procedure.
