I have the following balance devices:
- Balance 380 (6.1.3s2 build 1246)
- Balance 310 (5.4.4 build 1747)
First question is the balance 310’s dont seem to have AP controller; is this found in a later firmware or should it be there? From reading they should be able to run the AP Controller light.
Second question, is when I configure the 380 (1) to be AP controller, I’m having the following issue:
I have 6 AP devices (3 still to setup). If I use the current firmware listed below they show up in the AP controller for the balance 380.
3 devices on this: AP One AC Mini: 3.5.3s14-1632
3 devices on this: AP One AC Mini: 3.5.2 build 1540
However, if I upgrade to the latest firmware on the Mini devices as follows:
AP One AC Mini: 3.5.4-1681 (this is reported as the latest firmware)
Then they do not show up in the AP controller of the balance 380. Tried rebooting both AP and balance; but the only way they show up again is to reboot the AP’s into the older firmware (3.5.3).
James.
