Hi, I have a Peplink Balance 380 and a Cisco 887va ADSL router. I want to connect the Cisco 887va to my ADSL line and setup the Cisco in bridge mode so that the Peplink can do the dialling. I have completed my setup but the Peplink cannot dial, it keeps saying ‘no PPPoe service detected’. I have tested the Cisco using a Linux box and using Windows PPPOE connection and it works, just not on the Peplink. Has anybody tried doing this or can anybody send me a sample Cisco config that I can try on my router to see if I can solve the problem. The Peplink works when I connect a Billion router in bridge mode.
A ticket has been created for this and we will follow up with you accordingly.
Thanks. Here is my current Cisco configuration if you need it. Like I said, it works from a Linux pc & a Windows pc, but not from the Peplink:
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname data
boot-start-marker
boot-end-marker
enable secret password
no aaa new-model
memory-size iomem 10
crypto pki token default removal timeout 0
ip auth-proxy max-login-attempts 5
ip admission max-login-attempts 5
ip dhcp excluded-address 192.168.1.1 192.168.1.50
ip dhcp excluded-address 192.168.1.200 192.168.1.254
ip dhcp pool ccp-pool1
import all
network 192.168.1.0 255.255.255.0
domain-name domain.local
dns-server 8.8.8.8
default-router 192.168.1.254
ip name-server 8.8.8.8
ip cef
no ipv6 cef
license udi pid CISCO887VA-K9 sn FCZ1618C5LE
controller VDSL 0
ip ssh version 1
interface Ethernet0
no ip address
shutdown
interface ATM0
bandwidth 4096
no ip address
no atm ilmi-keepalive
bridge-group 1
pvc 8/35
encapsulation aal5snap
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
ip address 192.168.1.254 255.255.255.0
no ip route-cache
bridge-group 1
ip forward-protocol nd
no ip http server
no ip http secure-server
bridge 1 protocol ieee
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
transport input ssh
end
I have the exact same issue. What was the outcome from the ticket that was opened?
Customer changed Cisco router with another modem at the end.
May I know the model and firmware version for Balance and Cisco router?
Please upgrade to v6.2 to confirm this will help.
Thank you for your reply.
I have updated the firmware to 6.2, right after this issue but i am getting the same results.
Are you saying that there is compatibility issues between peplink and cisco routers?
I suspect there is compatibility issue. We do facing similar case before. Can you put a switch (dumb switch will do) in between B30 and Cisco router? If this doesn’t help please open ticket for us to take closer look.
