[edit:] problem solved. We had exhausted our DHCP pool of our internal DHCP server.
We’ve noticed a new problem since version 6.x of the firmware. Our PPTP server will sometimes stop responding to client requests.
Usually, a hard reboot would “solve” the problem, but the last time the problem wasn’t “solved” by rebooting. No clients (MacOSX, Windows, or iOS) are able to make a connection. No events are shown in the Peplink log.
Enabling the debug log on my mac, I see the following:
Tue Dec 15 22:23:04 2015 : publish_entry SCDSet() failed: Success!
Tue Dec 15 22:23:04 2015 : pptp_get_router_address
Tue Dec 15 22:23:04 2015 : pptp_get_router_address 192.168.1.1 from dict 1
Tue Dec 15 22:23:04 2015 : PPTP connecting to server 'mailx.charltonslaw.com' (112.120.80.132)...
Tue Dec 15 22:23:04 2015 : PPTP connection established.
Tue Dec 15 22:23:04 2015 : PPTP set port-mapping for en1, interface: 4, protocol: 0, privatePort: 0
Tue Dec 15 22:23:04 2015 : Using interface ppp0
Tue Dec 15 22:23:04 2015 : Connect: ppp0 <--> socket[34:17]
Tue Dec 15 22:23:07 2015 : MPPE 128-bit stateless compression enabled
Tue Dec 15 22:23:08 2015 : PPTP port-mapping for en1, interfaceIndex: 0, Protocol: None, Private Port: 0, Public Address: 0, Public Port: 0, TTL: 0.
Tue Dec 15 22:23:08 2015 : PPTP port-mapping for en1 inconsistent. is Connected: 1, Previous interface: 4, Current interface 0
Tue Dec 15 22:23:22 2015 : PPTP error when reading socket : EOF
Tue Dec 15 22:23:22 2015 : PPTP error when reading header : read -1, expected 12 bytes
Tue Dec 15 22:23:22 2015 : PPTP hangup
Tue Dec 15 22:23:22 2015 : MPPE disabled
Tue Dec 15 22:23:22 2015 : Connection terminated.
Tue Dec 15 22:23:22 2015 : PPTP clearing port-mapping for en1
Tue Dec 15 22:23:22 2015 : PPTP disconnecting...
Tue Dec 15 22:23:22 2015 : PPTP disconnected
From the log, it appears the PPTP server is not responding at all
After a hard reboot (pulling the power for 15 seconds), I see the following:
Wed Dec 16 11:51:47 2015 : publish_entry SCDSet() failed: Success!
Wed Dec 16 11:51:47 2015 : pptp_get_router_address
Wed Dec 16 11:51:47 2015 : pptp_get_router_address 192.168.1.1 from dict 1
Wed Dec 16 11:51:47 2015 : PPTP connecting to server 'mailz.charltonslaw.com' (223.255.133.202)...
Wed Dec 16 11:51:47 2015 : PPTP connection established.
Wed Dec 16 11:51:47 2015 : PPTP set port-mapping for en1, interface: 4, protocol: 0, privatePort: 0
Wed Dec 16 11:51:47 2015 : using link 0
Wed Dec 16 11:51:47 2015 : Using interface ppp0
Wed Dec 16 11:51:47 2015 : Connect: ppp0 <--> socket[34:17]
Wed Dec 16 11:51:47 2015 : sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0x5db0bedc> <pcomp> <accomp>]
Wed Dec 16 11:51:47 2015 : rcvd [LCP ConfReq id=0x1 <asyncmap 0x0> <auth chap MS-v2> <magic 0x62b9b495>]
Wed Dec 16 11:51:47 2015 : lcp_reqci: returning CONFACK.
Wed Dec 16 11:51:47 2015 : sent [LCP ConfAck id=0x1 <asyncmap 0x0> <auth chap MS-v2> <magic 0x62b9b495>]
Wed Dec 16 11:51:50 2015 : sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0x5db0bedc> <pcomp> <accomp>]
Wed Dec 16 11:51:50 2015 : rcvd [LCP ConfReq id=0x1 <asyncmap 0x0> <auth chap MS-v2> <magic 0x62b9b495>]
Wed Dec 16 11:51:50 2015 : lcp_reqci: returning CONFACK.
Wed Dec 16 11:51:50 2015 : sent [LCP ConfAck id=0x1 <asyncmap 0x0> <auth chap MS-v2> <magic 0x62b9b495>]
Wed Dec 16 11:51:50 2015 : rcvd [LCP ConfRej id=0x1 <pcomp> <accomp>]
Wed Dec 16 11:51:50 2015 : sent [LCP ConfReq id=0x2 <asyncmap 0x0> <magic 0x5db0bedc>]
Wed Dec 16 11:51:50 2015 : rcvd [LCP ConfAck id=0x2 <asyncmap 0x0> <magic 0x5db0bedc>]
Wed Dec 16 11:51:50 2015 : sent [LCP EchoReq id=0x0 magic=0x5db0bedc]
Wed Dec 16 11:51:50 2015 : rcvd [LCP EchoReq id=0x0 magic=0x62b9b495]
Wed Dec 16 11:51:50 2015 : sent [LCP EchoRep id=0x0 magic=0x5db0bedc]
Wed Dec 16 11:51:50 2015 : rcvd [CHAP Challenge id=0xd9 <98cddf6ebb4f41f3173120e2f831e300>, name = "pptpd"]
Wed Dec 16 11:51:50 2015 : sent [CHAP Response id=0xd9 <5ccd552f70ea05692bd5ef77c7f68f150000000000000000773ad5f34fd8d31df649e44d47bb36e9fbccd14d247ae80300>, name = "pdwalker"]
Wed Dec 16 11:51:50 2015 : rcvd [LCP EchoRep id=0x0 magic=0x62b9b495]
Wed Dec 16 11:51:50 2015 : rcvd [CHAP Success id=0xd9 "S=F071CBDDCEB2C774AC29514ACB3EA2BE3C192594 M=Access granted"]
Wed Dec 16 11:51:50 2015 : sent [CCP ConfReq id=0x1 <mppe +H -M +S +L -D -C>]
Wed Dec 16 11:51:50 2015 : rcvd [CCP ConfReq id=0x1 <mppe +H -M +S +L -D -C>]
Wed Dec 16 11:51:50 2015 : sent [CCP ConfNak id=0x1 <mppe +H -M +S -L -D -C>]
Wed Dec 16 11:51:50 2015 : rcvd [CCP ConfNak id=0x1 <mppe +H -M +S -L -D -C>]
Wed Dec 16 11:51:50 2015 : sent [CCP ConfReq id=0x2 <mppe +H -M +S -L -D -C>]
Wed Dec 16 11:51:50 2015 : rcvd [CCP ConfReq id=0x2 <mppe +H -M +S -L -D -C>]
Wed Dec 16 11:51:50 2015 : sent [CCP ConfAck id=0x2 <mppe +H -M +S -L -D -C>]
Wed Dec 16 11:51:50 2015 : rcvd [CCP ConfAck id=0x2 <mppe +H -M +S -L -D -C>]
Wed Dec 16 11:51:50 2015 : MPPE 128-bit stateless compression enabled
Wed Dec 16 11:51:50 2015 : sent [IPCP ConfReq id=0x1 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns3 0.0.0.0>]
Wed Dec 16 11:51:50 2015 : sent [IPV6CP ConfReq id=0x1 <addr fe80::426c:8fff:fe2a:baeb>]
Wed Dec 16 11:51:50 2015 : sent [ACSCP ConfReq id=0x1 <route vers 16777216> <domain vers 16777216>]
Wed Dec 16 11:51:50 2015 : PPTP port-mapping for en1, interfaceIndex: 0, Protocol: None, Private Port: 0, Public Address: 0, Public Port: 0, TTL: 0.
Wed Dec 16 11:51:50 2015 : PPTP port-mapping for en1 inconsistent. is Connected: 1, Previous interface: 4, Current interface 0
Wed Dec 16 11:51:53 2015 : sent [IPCP ConfReq id=0x1 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns3 0.0.0.0>]
Wed Dec 16 11:51:53 2015 : sent [IPV6CP ConfReq id=0x1 <addr fe80::426c:8fff:fe2a:baeb>]
Wed Dec 16 11:51:53 2015 : sent [ACSCP ConfReq id=0x1 <route vers 16777216> <domain vers 16777216>]
Wed Dec 16 11:51:56 2015 : Received protocol dictionaries
Wed Dec 16 11:51:56 2015 : sent [IPCP ConfReq id=0x1 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns3 0.0.0.0>]
Wed Dec 16 11:51:56 2015 : sent [IPV6CP ConfReq id=0x1 <addr fe80::426c:8fff:fe2a:baeb>]
Wed Dec 16 11:51:56 2015 : sent [ACSCP ConfReq id=0x1 <route vers 16777216> <domain vers 16777216>]
Wed Dec 16 11:51:59 2015 : sent [IPCP ConfReq id=0x1 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns3 0.0.0.0>]
Wed Dec 16 11:51:59 2015 : sent [IPV6CP ConfReq id=0x1 <addr fe80::426c:8fff:fe2a:baeb>]
Wed Dec 16 11:51:59 2015 : sent [ACSCP ConfReq id=0x1 <route vers 16777216> <domain vers 16777216>]
Wed Dec 16 11:52:02 2015 : sent [IPCP ConfReq id=0x1 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns3 0.0.0.0>]
Wed Dec 16 11:52:02 2015 : sent [IPV6CP ConfReq id=0x1 <addr fe80::426c:8fff:fe2a:baeb>]
Wed Dec 16 11:52:02 2015 : sent [ACSCP ConfReq id=0x1 <route vers 16777216> <domain vers 16777216>]
Wed Dec 16 11:52:04 2015 : PPTP error when reading socket : EOF
Wed Dec 16 11:52:04 2015 : PPTP error when reading header : read -1, expected 12 bytes
Wed Dec 16 11:52:04 2015 : PPTP hangup
Wed Dec 16 11:52:04 2015 : MPPE disabled
Wed Dec 16 11:52:04 2015 : sent [LCP TermReq id=0x3 "MPPE disabled"]
Wed Dec 16 11:52:04 2015 : Connection terminated.
Wed Dec 16 11:52:04 2015 : PPTP clearing port-mapping for en1
Wed Dec 16 11:52:04 2015 : PPTP disconnecting...
Wed Dec 16 11:52:04 2015 : PPTP disconnected
So I can see something happening, but eventually the PPTP server stops responding.
I have confirmed that the user accounts and passwords have not changed. I can confirm that no firewall rules are in place that block pptp.
Can anyone make any suggestions on how I can further diagnose or debug this issue? Should I reset the router and enter in the configuration entirely from scratch?
Any help or advice would be greatly appreciated.
