want to ask for the peplink balance 380 with the old firmware 5.3.2, the unit does not have speed fusion capability. Want to check if it is upgraded to the newer firmware 6.3.3, would it get the speed fusion capability ?
Hi @Joseph_Li,
Yes, this should enable you to use SpeedFusion.
Besides SpeedFusion it will give you a few other new features aswell.
Make sure to update the firmware!
