Hello all,
My Peplink Device is stuck on booting up, seems Compact Flash is corrupted. any way to solve this issue
Hello all,
I have had this on B380 recently. If unit is covered by one of the warranty plans then raise this now as unit will have to be fixed by manufacturer - you will need an RMA number form Peplink. If not then raise a call with Peplink support and see what they say or contact your local partner.
Have you attached to the console port? You may be able to boot to the second firmware file.
