Peplink Balance 305 with Azure
Hi there,
I was looking to see if anyone has had any luck getting getting the Peplink Balance 305 working with the Azure Virtual Network gateway using Either IKEv1 or IKEv2 Route Based VPN.
If so is the VPN stable and what are the Phase 1 and Phase 2 proposal settings that you have used?
Thanks in advance!
