Peplink Balance 305 HA Config Sync
Hello, is there a way i can confirm that the config from the master is being correctly synced to the slave at any config updates ?
@Vinicius_Batistela, You have 3 options to confirm: local login through main router, local login through HA/secondary device, and lastly InControl will tell you the last sync.
Hope this helps.
  1. Local Master - Its at the very bottom of the dashboard page.
  2. For Secondary Device - its also at the very bottom of the dashboard page
  3. InControl - Right Side of the status page for the device
