I am having a peplink balance 30 and work well with sim card and wan port; however, i am not able connect the wireless connection from the peplink balance 30 even after i had enabled the wireless connection and chose to broadcast the SSID. the SSID does not show up in my laptop or my phone wifi search, any setup need to be done or wireless not working?
Please take screenshot of Balance Dashboard. Do you have Balance 30LTE or 30PRO model ?
30PRO has Wi-Fi interface and 30LTE- no(only AP Controller Functionality).
That’s correct. However you may wish to note that your product contains a very capable AP controller – built-in – which will allow you to add and integrate external APs of which Peplink has a good selection. You’ll be able to place the AP(s) where you need the coverage.
