I am trying to connect to a network (192.168.10.0/24 - it has the peplink 30 firewall) from another network using the pptp client. Using the pptp setup in windows, everything works fine but once i connect to the 192.168.10.0 network, i cannot see any devices on that network other than the peplink device and i cannot see anything on my local network. i am new to pptp vpn’ing - is there definitions i need to put someplace for the peplink to allow me to see everything on 192.168.10.0 and is there something i need to turn on so i can still see my local network when i am connected?
edit: i just used this docto solve the split tunnel issue - still need help on seeing devices on the remote network
edit 2: i feel like the following info would be helpful: there is a device i CAN ping from the peplink device (192.168.10.5) but i cannot from the laptop i am pptp’d into the network with. it screams out to me that i need to define the network (LAN) as accessible from the pptp but i am not sure where to do that. (possibly a NAT mapping?)
it would appear that the default firewall inbound rule is “allow” to any any, so that is what is there now.
i would think this is a bad default rule. also, i would have thought my question would be simple. i have a peplink with devices behind it, i cannot see them when logged in with pptp, i can only see the peplink. the peplink can ping all the devices behind it. what do i need to change?
I had this issue, 5 min search on the forum for this thread, as suspected was a fw rule issue. implemented the inbound rule for my LAN subnet - sorted. Thanks.
