Dear,
I have two link no peplink, but the router used one full while the other is the standby.
Configuration that I should do?
thx
Dear,
thx
If you would like to load balance with your two connections, go to: Network>WAN>WAN2 and check the “Always-on” option instead of Backup Priority.
thx for reply
configuring in this way is already
If it is configured this way, and it is still showing as standby I would open a support ticket and one of our technical members will be able assist you further.
Ok, I’ll do it.
thx
