Peplink Balance 2500 how to flash bandwidth usage
Hi @abdrhmn47,
What did you meant by “how to flash bandwidth usage” ? You can check bandwidth usage on the device level in Status > Usage Reports. You can check WAN usage in real time, hourly, daily or monthly reports. Or if you are using InControl 2 you can check device WAN usage reports in Group level > Reports > Usage Reports. Using InControl 2 you can see aggregated WAN usage from all the devices in your group or you can filter this information by product, tags. Also data usage can be shown in hourly, daily, monthly reports.
Regards,
Rokas
