Do all hardware revisions (HW1-HW4) include Speedfusion Hotfailover, Smoothing, and Bonding? Is there any visible/physical differences between the HW revisions?
Thanks!
Thanks!
Hi @mystery,
I’ve found a few links which should answer your question:-
Summary of the release date for each model. Note, Hardware 2 and 3 are the same > Here <
Datasheet for the Hardware version 1 (other Balance models at the time are also shown). This is from March 2010 > Here <
Datasheet for Hardware versions 2 & 3. This also shows other Balance models available at that time - April 2012 > Here <
The current hardware version is release 4 - the specs for this model are available > Here <
Please note, WAN Smoothing is a new feature available from Firmware 7, therefore this will not apply to Hardware 1, but should apply to the other hardware versions.
Latest Firmware (5.4.9) for HW 1 is available > Here <
Latest Firmware (7.1.2) for HW 2 and 3 is available > Here <
Latest Firmware (7.1.2) for HW 4 is available > Here <
You can also try our Beta Firmware (8.0.0b3)
Hardware 2 / 3 > Here <
Hardware 4 > Here <
I hope this helps,
Steve
Thank you, that is VERY helpful!
One last question, in order to use Speedfusion, is an active service/totalcare subscription required?
Thanks again
Hi Mystery,
You can configure SpeedFusion manually on each device, this does NOT require an active service / totalcare or subscription to use SpeedFusion. However, to manage the SpeedFusion connections using InControl2, you would.
I hope this helps,
Steve
So I see on the newer 210/310 the Speedfusion throuhput was 150 mbps unencrypted or 80 mbps encrypted. Any idea on the hardware 2/3? I only see mention of 30 mbps ‘bonded’ … what is that in reference to?
Thank you!
Hi Mystery,
I’ve found a slightly later link to the Balance 210/310 - still hardware 2/3 > Here < This shows the 30Mb/s as “PepVPN/SpeedFusion Throughput”.
I hope this helps,
Steve
Thank you Steve
Thanks Steve. Do you know if that 30mbps is for both encrypted and unencrypted or will the throughput vary depending? Thanks again
Hi Mystery,
I can confirm that this 30Mb/s PepVPN / SpeedFusion throughput is encrypted.
Hope this helps,
Steve
