We have a Balance 210 that appears to be blocking DVR traffic from the local LAN out to the WAN port
I ping the DVR which is plugged into our cable modem directly and is being given a 10.1.10.150 IP address internally.
The firewall on the comcast modem is setup to forward port 80, 8000 and 8001 to the .150 IP which is our DVR.
Then our cameras all plug into that DVR via ethernet. There is a integrated switch.
Before the Peplink we had a Watchguard. Now after the Peplink has been installed, we can’t view or manage our cameras from the LAN. Our LAN is 10.0.0.x given out by the Peplink.
We can ping the DVR on 10.1.10.150
The traffic goes from the local address of the computer to the gateway of 10.0.0.1, out to the static IP, then back down to the 10.1.10.150 Local IP on the cable modem.
But our thought is that the traffic isn’t coming back in correctly.
Has any one had an issue where they have had similar issues? A device or port forwarding that isn’t working for local LAN devices after the Peplink is put in place?
