I just got a pep link balance 20 and AP on 300m and I don’t know how to set up my access point. I don’t know how to set a password on the access points ad there is no menu in web admin??? Thanks
If this is a first time setup for the AP One 300M. You will need to hook up a Ethernet cable to the device and then to your laptop. Then you will need to set a static ip to your pc (use 192.168.0.5) then set a subnet mask of 255.255.255.0 and then the gateway ip will be 192.168.0.3. Then open a web browser and type in the default gateway ip and this should bring you to the web interface. The password will be admin/public. Then to set your own username and password. This will be done on the Web Administration page.
