HI,
I am currently using Peplink Balance 20.
I would liek to see the TOTAL usage of an IP , and i would like also to create username against and IP, or a name identification. Also I would like just to close certain applications , like SKYPE , or Torrents.
How is that possible.
Regards
Shoaib
From the Status -> Bandwidth, you can see the real-time, hourly, daily or monthly bandwidth utilisation. It will further show the utilisation for each IP address when you click into it but there is no option to create username or name identification for the IP address.
There is a Firewall feature in the Balance 20 which allow you to block certain access by IP address and services/ports. However, for Balance 580 and above, there is a beta feature which allow you to block IM or P2P file transfer.
