On a new install of this router, I keep getting prompted to login from a popup. Usually, I have to enter the login information at least twice before it accepts the login. If I close the login prompt without logging in, it still allows me to make changes to the router.
Hardware Revision: 6
Firmware: 8.0.0 build 3623
Is there a setting on the router that is causing this to happen? Or, is there something I need to do in order to fix a problem in the router?
Thanks in advance!
