Peplink Balance 1350 Config H1 to Peplink Balance 30
Hi There is there a way to Upload Configurations of a Balance 1350 to an Balance 30, to be used as backup?
That’s quite a contrast in model specification. No you can’t so this yourself. Engineering can frequently convert configurations between device models when asked but that process will take time and so wouldn’t suit a backup device situation like this.
Suggest you make it a manual process to replicate those configurations that can be copied as and when you make changes to the B1350.
