Can you please point me document that explains how to use peplink devices as WiFi hotspot? I am assuming there should be some way since there are SIM slots.
Thank you.
Thank you.
I’m having some trouble understanding your application.
I have some questions before I can answer your question.
What Peplink/Pepwave model are you using?
What are you trying to accomplish?
Are you trying to use this Peplink/Pepwave device as a mobile WiFi hotspot?
Thank you!
Pepwave products aren’t really designed to be used as a mobile WiFi hotspot.
Of course, you can take the unit with you and plug it into a power supply when you need it.
You can then connect the mobile phone to the WiFi signal of the Pepwave MAX BR1 Mini.
As long as the Pepwave MAX BR1 Mini has a connection via one of it’s SIM-cards, you’re good to go.
If you look at it that way, you can use it as a mobile WiFi hotspot.
But it doesn’t have a built-in battery for example, you will always need a source of power.
Will this WiFi hotspot need any password? Is there any default one to start with?
Really appreciate the quick response.
Thank you.
Okay, then if the Pepwave MAX BR1 Mini is configured correctly, you should have no problems.
Yes, the default WiFi password can be found on the bottom of the device, on a silver sticker.
Just look for ‘AP Password’ on the silver sticker.
Great. Thank you so much.
