Peplink AAD issue
We have site with 10.140.0.0/16 as its local subnets. The local subnets are on a palo alto 440 . The palo alto is connected to Peplink MAX BR2 Pro. Peplink MAX BR2 Pro is connected to Fusion hub in Azure and Fusion hub runs OSPF to reach the subnets in Azure. 10.0.0.0/24 subnet Azure AD is on this 10.0.0.0/24 subnet. We are seeing intermittent issues with connectivity to Azure AD. We have setup a powershell script to run securechannel -computername every 5 minutes to check the connectivity and it shows false. While this happens only for the site with peplink, Azure AD works fine for other sites, please help fix this issue, where could be the issue, I am new to peplink. The issue is intermittent, it works on and off, please help fix this issue.
