hi Support,
i’m using 5.3.9 firmware and i’m using the wlan controller function. i’m currently using 2 AP.
sometimes the cable of one of the AP switch off (not an AP problem. external problem) and the manager report correctly that only one AP is online;
but:
the AP without cable still running (plugged with wireless on) so until i switch back on the cable all the user aren’t able to connect on the internet. is there a way to detect when there is no cable and turn off wireless settings so all wireless user can go to the another working AP??
maybe consider this as a WISH feature.
thanks and let me know
