I have an 800Mbps Fibre internet.
My problem is I cannot get the speed with Peplink 580. I can get that speed using another cheaper router (asus).
My connection is as follows :
Telecoms UNIFI 800Mbps → Telecoms Modem → peplink 580 → LAN1 → Macbook Ookla Speedtest same server (420Mbps)
Telecoms UNIFI 800Mbps → Telecoms Modem → Asus Router → LAN1 → Macbook Ookla Speedtest same server (825Mbps)
My ports are set at 1Gbps
Connection is Only by WAN and not WiFi
Just surprised why the speed can only be obtained by a home grade router and not the enterprise grade P{Peplink 580 running the latest hardware and firmware.
Thank you
Yoga
