Hi, I need a little bit help from Peplink community,
I need to run upgrade for balance 580 Hardware revision - 3, from version 6.1.3 to latest version, as i saw it was 7.0.0.
Is that possible to do it directly? Or i need to do steps like in Fortigate?
You can just update directly to 7.0.0 Thanks.
Thank you for fast response.
Hi…i am a new user here. I also had the similar question and same type of setup with me. I just updated it directly and it worked. Initially i faced some issues regarding performance, but now it is working fine only.
