Hi, I’d like to know if there is a difference in max range between the different Peplink models.
I know a better antenna, a more directional antenna, shorter cable run, etc. can help to get a better range. But I would like to know if perhaps the electronics on a Peplink MBX are more sensitive compared to a MAX BR1 for example, so when connected to the same antenna installation it gets a better range.
Also, how would this compare to the average mobile phone? as an example, lets say we are in a boat sailing away from shore. We have a mobile phone on one hand, and a peplink LTE router with the standard indoor antennas on the other hand. As we get further and further away, should we expect both of them loosing connectivity more or less at the same time?
